After fighting the kingpins and wrestling with the I-beams, I find that I gave away a valuable part of my parts truck...the brake line brackets. I would be much further along if I'd stop doing STUPID things.
Does anyone have a set of brackets for a fellow fron end fighter?
jck
UGH! The brake line brackets are different
- jck_in_nc
Frame-off Restore
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
- lobuck76
re: UGH! The brake line brackets are different
Always one more trip to the salvage. One bracket is bolted on, and the other is riveted. It's easier to get the bolted bracket off two different trucks.
'71 F-100
- jck_in_nc
...so the left and right side brackets are interchangable?
jck
jck
Frame-off Restore
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
- willowbilly3
I hope you don't come behind me, I beat the drivers side one out of the way so I can get the steeing box bolt.
Yes, the two brackets are identical and are interchangeable.
- jck_in_nc
I tried to make the drum brackets work for hours before I went back and read the article again. I'm sure Keith knows.
jck
jck
Frame-off Restore
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
1967 Longbed F-100
FE Engine, 3-speed
Greensboro, NC
The holes for the brake lines are different. IIRC the drum brake brackets have a star-shape hole and the disc brake brackets have more of a squared-off oval. (I'm just going by memory here, so I might be wrong.) Also the disc brake brackets extend out a little farther.
- lobuck76
