Ran the 72 at the track
Ran an 8.56 at 82.xx mph. Too bad that out of a couple hundred cars at the track, only about 4 of them were remotely stock muscle cars. Just about everything that was there that wasn't a dedicated drag car was still pretty hopped up, most with nitrous. So, needless to say, I was one of a very few that wasn't running 7's or better, most way better. There was a new camaro that ran low 9's(I think) and a couple of newer mustangs running high 8's and low 9's, but I never lined up against them. Also a guy I knew had his turbo'ed Neon there running high 8's. I had 3 runs, all against cars running low 7's, so I saw lots of taillights. Did see a bump there called "Godzilla" that was an all out drag truck. Looked really cool. Had a stroked 460, if I remember correctly. Didn't get to see him, or much anything else run, as I was in line waiting to run most of the night. It was a major adrenaline rush, though. First run I was pretty sure I was going into cardiac arrest.
- Mancar1
Re: Ran the 72 at the track
Was it an 1/8 mile???
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- AK F100
Good run, sounds like you had a blast.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
That would be a heck of a weird 1/4 mile run.Mancar1 wrote:Was it an 1/8 mile???
- TX69F100
Sounds like a lot of fun!
Do you mind giving the specs on your setup?
dang thats a hard runniing bump
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
390, .030 over, forged rods and pistons, 10:1, C8AE-H heads with 2.09/1.65 valves, comp 288R roller cam, Performer RPM, Demon 750, Mallory Unilite with MSD Digital 6, Hedman headers, full 3" exhaust. If I had it to do over, I'd have gone with a 445 stroker kit from Barry R at Survival Motorsports and Edelbrock heads. Probably would have gottten another 100+ horsepower for only $2000 or so. Live and learn.TX69F100 wrote:Sounds like a lot of fun!
- TX69F100
Your setup is very similar to mine, but I have the Edelbrock heads, Demon 650 and a flat tappet cam (soon to be swapped). I feel the same way about the stroker kit.
What trans and rear gear are you running?
Also, where do you live? Is Dodd City, TX...just east of Bonham?
- HayHauler
NICE!
What was your 60ft?
No problem can withstand the assault of sustained thinking. -- Voltaire
- ezernut9mm
congrats, those are pretty good times.
Running the C-6 and 4.11 gears. Yep, just east of Bonham. I notice you aren't far from me.TX69F100 wrote:Your setup is very similar to mine, but I have the Edelbrock heads, Demon 650 and a flat tappet cam (soon to be swapped). I feel the same way about the stroker kit.
Actually, my 60' was right at 2 seconds, which isn't that great.HayHauler wrote:NICE!What was your 60ft?
- TX69F100
Yup, not too far. Perhaps we can get together one day and play trucks. LoL. I'd like to check out that 72.
I just got my C-6 back together last night. Hopefully I'll have it back in the truck by the end of the weekend.
- shiny390
What tire are you running?
