That's what I'm talking about.
I'm on my 3rd 390 over the years, in pickups, never had a problem with the pulling, hauling, nor the racing.flyboy2610 wrote:The 390 builds it's power higher in the powerband than a 360 does. The 390 is a sport engine, the 360 is a truck engine.
You were trying to use a racehorse as a draft horse.
A truck 390 is not a racehorse unless one makes it so.Mancar1 wrote:I'm on my 3rd 390 over the years, in pickups, never had a problem with the pulling, hauling, nor the racing.flyboy2610 wrote:The 390 builds it's power higher in the powerband than a 360 does. The 390 is a sport engine, the 360 is a truck engine.
Is that because a 300 is weak?BRUTUS_T_HOG wrote:doesn't look too low. you have a 6cyl? chances are that the engine/gears just weren't powerful enough to haul the load fast
