In my 67' F350 I have the T18 manual trans and will be putting in the C6 but want a clean look so want it on my column... Just got my LMC catalog and was wondering if it is easy to convert my manual column to the automatic by getting a few pieces ie... shift colar, shift indicator etc..?
Todd
convert manual column to automatic?
- zakt
1972 Ford F350 crewcab
re: convert manual column to automatic?
You must get an automatic column, also get the column to trans gear selector rod, trans to carb kickdown rod. Did the trans come from a car or a truck? The gear selector levers are different on cars and trucks.
- zakt
