No rear traction!
- nikon4u
No rear traction!
Is it just me or does everybody have no rear traction. It rained today in KC and I pealed out at every green light. Now I do have the 352 and I think that the throtle is a little sticky and there is no such thing as a slow start, but still it seems like there shouldn't be this bad of traction.
I just got my web site up! Check it out!
http://www.Handyman-for-rent.com
"If it ain't broke, don't lend it"
--Red Green
http://www.fordification.com/galleries/ ... ?cat=10491
--Red Green
- heep70
re: No rear traction!
These old Fords are light in the butt. Is this your first rain. Maybe a build up of oils on the road surface. Thats what the Washington people use for an excuse anyway. Only thing is we never get the hard rains to wash the oil off the road surface. Thats the other half of the excuse.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- rjewkes
Mine has good traction rain or shine. But then I carry all my tools with me.
Mine was like that until I put a limited slip in it. That really helped alot. Used to get stuck on wet grass. Now I go about anywhere I need to.
If it's very bad I take the 4 wheel drive Battle wagon as my daughter calls it.
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Wes
Also in wet weather You should check the air pressure in your tires, Most people over inflate the rear tires, esp if you inflate to the pressure listed on the side wall. I don't care what kind of tire you M/S all session if it's over inflated for your trucks load, it will get poor traction.
If the tread on tires is thinner in middle you have been running over inflated. D and E range tires are good for 3000 pds+ at 50 (D) and 80 (E), your empty bed doesn't weigh 6000 pds. An add bounus to running lower pressures is softer ride.
Well my 2 cents
Wes
Well my 2 cents
Wes
- 71-F-250SC-72-F-250C
My truck does not get good traction at all in the rain. I need new tires, but my truck will just slide in the rain. Forget about stop lights or signs when it is raining. Another bad thing is the brakes pull a little bit, so just about every time we get a good rain, I slide my truck around into an unexpected 180.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
72 f-250 Custom
03 mach1 mustang
- nikon4u
unexpected.
--Red Green
--Red Green
Hey I drive a 250,you think rain is bad...try the canadian winters.I either have to carry 3 railway ties or park it for the winter.
I think its much like comparing the old vans and the new vans. make sure you have a healthy passenger to help push...
driving a 1968 Mercury Camper Special that needs a lil facelift
- greasemonkey060
Re: re: No rear traction!
i aint ashamed to spin the tires in the rain. it still makes the ricer boys piss their pants.heep70 wrote:These old Fords are light in the butt. Is this your first rain. Maybe a build up of oils on the road surface. Thats what the Washington people use for an excuse anyway. Only thing is we never get the hard rains to wash the oil off the road surface. Thats the other half of the excuse.
'64 F100 SWB 8" notch, & triangulated four link w/ 2600 Firestone bags out back.
'67 F100 SWB STOCK.
'67 F100 SWB STOCK.
