turn signal swich harnesses connector
- 69f-100
I need the male and female ends of the turn signal harnesses conector for my new switch.
- 91Bear
Re: turn signal swich harnesses connector
You can just go buy six-terminal connectors (male and female) from Radio Shack online. They won't be the same as stock but they will work just fine.
http://www.radioshack.com/product/index ... Id=2103251
http://www.radioshack.com/product/index ... Id=2062448
Here's another one:
http://www.molex.com/molex/products/fam ... troduction
- 69f-100
there is 7 wires for the turn signal switch correct?
If memory serves me correctly there was a change in the wiring for our turn signal switches. One version for the 67-69 and another for the 70-72. My 71' has seven wires, and it seems like the 67-69 might have had two harnesses for the turn signal switch, (one with two wires)? I can't seem to be able to find the thread I'm looking for...69f-100 on Mon Jul 02, 2012 2:03 pm
If you get a seven wire harness you would have more than enough harness for it.
http://www.fordification.com/tech/wirin ... _81-85.jpg
Ryan,
Here's the picture I was looking for-with the image that shows the difference in the years of wiring harness:
- 69f-100
it doesn't need to be original, i just need to find something that will work and looks decent.
