lifting a 2wd
- Heavenlyfire
- rjewkes
Before somebody flames you real bad Heavenly, This is raising it question i think you thought you had wolfpaks' question of lowering it in your head?
- heep70
Boots would be the dude to talk to.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- boots
re: lifting a 2wd
Well, You have to get some lift coils, or some coil spacers. I think lift coils are the way to go though. Check rancho or skyjacker for them. After you get thoes, You will find your camber will be off. You have to either get your i-beams bent, or make drop brackets for your i-beam (which I did). Next, you must drop your radius arms. I have a 4" lift and Im in the process of doing about a 3" drop of the arms, and im extending them 10.5 inches. If you lift 4" or more you will probably need a drop pitman arm also. For the back, you can go ahead and do lift blocks. I would not go over 4" inches for the blocks though. I have blocks, but soon im going to fab up drop brackets for the leaf's, or just get sky brackets. Any other questions just ask, hope this helps.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Heavenlyfire
re: lifting a 2wd
http://fordification.com/forum/viewtopic.php?t=3796
Give this link a look at and you can read about the whole thing
. It was fun.
- ivansgreat
re: lifting a 2wd
Thanks to all of you. I have one more question. Who makes a good product for me to use to give my truck a lift? I've been looking but can't find something for a 2wd. All I find is Bronco and 4wd lifts.
Ivan
1968 F100 2wd
302
1968 F100 2wd
302
- heep70
Boots mentioned Skyjacker or Rancho. Look for F100 4x4 coils.
Greg
- 460 crew
Autofab.com has 2wd lifts. quality stuff
- mrung0wa
re: lifting a 2wd
YeaH,
:thup:
I must commend Brother boots he has really done his homework and I plan to utilize his drawings for the front of ol' Jethro.
Lawrence
Lawrence
- ivansgreat
re: lifting a 2wd
Once again, thank you all. I really learned a lot about my options.
Ivan
1968 F100 2wd
302
1968 F100 2wd
302
- boots
re: lifting a 2wd
no problem!
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
Re: re: lifting a 2wd
yea but now i gotta go do biologymrung0wa wrote:YeaH,:thup:
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
