I hooked my traile house up to move it after an extensive rebuild, and plugged in the 4 pin driving light connector. The lights all worked fine then I pulled the wheel chocks, and went back around, and all the lights were out. I suspect a bad ground or a blown fuse, but can anyone tell me if there is a fuse in the fuse box for that, or do I need to look at the twelve volt converter in the trailer?
I looked at the schematic on the wiring diagrams section and it shows the amperage of the fuses but not the component they go to?
4 pin trailer lights.
- 72bumbee
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Mark Twain
Re: 4 pin trailer lights.
If your truck lights are working it's not a fuse in the truck it's probably a ground problem.
It may have been grounding through the trailer bar until you moved it.
- 72bumbee
sorry it took so long, but that was the issue! Thank you!!
Mark Twain
Mark Twain
- ToughOldFord
Haaaaa, a five year hiatus for a reply! See, I'm not the only one!72bumbee wrote:sorry it took so long, but that was the issue! Thank you!!
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
