kingpin kit reinstallation
- Billybobjunky
Ok guys, happy day, I finally got my new kingpin kit from LMC. My question to you is those lil circle bearing lookin things that come with it. Where do they go? Between the top of the i-beam and the spindle? Also, what all do I need to know about installin these things because me and a friend of mine are gonna press and ream em and he's only done a couple on a few ford tractors so what do I need to advise him about. Thanks guys! I'll have pictures up when it's all said and done, i painted everything all pretty.
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
-'77 V8 [[[410]]]
-'74 C6
re: kingpin kit reinstallation
They go on the bottom of the axle, between it and the spindle. The shims
go under the bearing. Put as many shims in as will fit in. Grease it up real
good after you get it together.
