PS fluid
PS fluid
In a saginaw box am I supposed to use power steering fluid or ATF? I think both fluids are the same but Im not 100% sure.
- Thundercat6870
re: PS fluid
I use power steering fluid only. I've heard from a lot of people that tranny fluid over time will degrade the seals. I always flush it every couple of years to keep it from getting old and overheated. A tranny cooler will work for power steering too to keep the fluid cooler.
MADD MODDS Custom Restification & Fabrication
Two 68 F-100 SHB's one 4X4
68 Cougar XR-7
Three 70 Cougars, Two Xr-7's and one Eliminator clone
68 Thunderbird suicide doors W/factory console
87 Thunderbird 289 H.O. MassAir T-5
68 Cougar XR-7
re: PS fluid
ATF works better. It won't hurt the seal's. Most of the P/S fluid they
sell is junk. The best stuff to use is the hydraulic fluid they use in tow
truck's to run the bed. JMO.
