Adjusting temp gauge
- Kurt Combs
Is it possible to adjust the temp gauge? If so, can someone please tell me how to do this adjustment, my temp registers too low. Thanks.
Kurt
1972 F-250
1972 F-250
Re: Adjusting temp gauge
Is your gas gage reading off also? I just adjusted mine but all of the gages (gas - temp - oil) were off so I'm wondering if its just that gage or all of them - the adjustment that is on the back of the cluster does all of them at the same time. Dont wanna steer you in the wrong direction......
Just went back and found the thread for the adjustment - this is what I used to adjust mine.....
http://fordification.com/forum/viewtopi ... =8&t=63385
1997 Honda CBR 900RR
- Kurt Combs
I already adjusted the resistor, but my temp reads really low. Reading some old posts I found that someone mentioned adjusting each gauge individually, which seems like what I need. My gas gauge is a 7/8 when full, oil pressure is high, and temp is really low. So I have something else going on and adjusting a gauge seems like it might work.
Kurt
1972 F-250
1972 F-250
