Jack handle storage?
- cdnwillyg
Need a little info here about how the handle for the jack is stored under the seat. I got a jack and handle from a 67 so I'm hoping it fits under the seat of my 68, but it seems a little long and I have no tie down clips so a pic would be awesome please.
Thanks
1968 Mercury M250 Camper Special
FE-390,570CFM 4bbl, C6 Automatic, PS, PB front disk.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
- cdnwillyg
Re: Jack handle storage?
All good here found a pic that shows the handle and clamps.
:drive:Willy
:drive:Willy
- popeyes71
Share your findings with the rest of the class.cdnwillyg wrote:All good here found a pic that shows the handle and clamps.
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
- cdnwillyg
Sorry Pat my bad! The green u shaped clip coming thru the carpet is the wheel wrench holder...no got that yet.
The two clips that hold the jack handle down were actual still in my parts, good thing.
:drive:Willy
:drive:Willy
Let me know if you find a source for the clips/hold downs.cdnwillyg wrote:Sorry Pat my bad! The green u shaped clip coming thru the carpet is the wheel wrench holder...no got that yet.
- cdnwillyg
They would be easy to make not much there!
:drive:Willy
:drive:Willy
Is it a different location for those of us that have seats that won’t flip forward? I found mine in engine compartment next to radiator.
1972 F250 4x4 XLT stock but P.O. hacked
2010 F350 CC LB 4x4 stock
- cdnwillyg
Yeah Mike i have seen trucks with them there. Kind of different as they go across the engine bay??
:drive:Willy
:drive:Willy
Lol ok that’s worse then where I found mine. Mine is sitting between radiator and core support. Just laying there no brackets...can’t be rightcdnwillyg wrote:Yeah Mike i have seen trucks with them there. Kind of different as they go across the engine bay??
That's where mine is stored also.MikeB wrote:Lol ok that’s worse then where I found mine. Mine is sitting between radiator and core support. Just laying there no brackets...can’t be rightcdnwillyg wrote:Yeah Mike i have seen trucks with them there. Kind of different as they go across the engine bay??
1969 F100, 390, 3 Speed, 2WD
Does it have clips or brackets? If so do you mind posting a pic? Mine is just sitting there loose.pchelp101 wrote:That's where mine is stored also.MikeB wrote:Lol ok that’s worse then where I found mine. Mine is sitting between radiator and core support. Just laying there no brackets...can’t be rightcdnwillyg wrote:Yeah Mike i have seen trucks with them there. Kind of different as they go across the engine bay??
Well just found my clips behind the seat buried in dirt and trash. It makes sense when the seat does not fold forward that getting to the tools would be aggravating thus placing it in the engine compartment would be a good idea.
