67 f100 rear disc brake conversion
boys, has anyone attempted the LMC TRUCK rear disc brake conversion kit for a 67-72 f100?
Re: 67 f100 rear disc brake conversion
nobody? I was looking at their kit yesterday. Did you wind up buying it?
i did end up buying the lmc rear disc conversion. have had it on truck for a few years now without an issue... just make sure to get the right proprtioning valve for the rear disc off the master cylinder.i also did the front disc brake conversion by getting the parts from a 74. just to be safe order a set of replacement pads for the rear disc. nice to have in reserve .
how did the park brake part work out? it says you use your own cables? My truck already has mid 70's front disc on it and a booster and 1 1/8 MC with aftermarket adjustable proportioning valve
i apologise for the late response,
i did use the factory parking brake cables. i may have made some adjustments on the transition from the single cable to dual cable... but it was simple.
again sorry for late response.
