My 1969 F250 Floor pans and Cab mounts are shot. I can’t take it any more and would really like to get it fixed. Unfortunately, I have absolutely no welding experience.. is this a job I could research and figure out on my own?
I love that You make it sound so easy my friend haha That alone gives me all the confidence I need to get this done. At first I was going to fix the cab mounts without removing the cab but it looks a lot cleaner doing the whole underside of the cab. What brand/model welder do you recommend?sargentrs wrote:A liitle of both. I would start with the cab mounts first. Looks like where the upper edge of the cab mount meets the floor pan, the pan is still pretty solid. Mark the top edge and sides of your old cab mount onto the existing floor pan. Then cut the cab mount loose. The bottom flange of the cab mount is spot/plug welded to the floor pan but since you're replacing that you can cut the floor section out without grinding off those welds. Then locate your new cab mount at the top along the outline you made but leave the rest loose. Cut your old floor pan out and tack the new one in place. Fold your cab mount down against the pan and tack it. Then weld it all out. Here's a photo of mine with the cab mount hanging over the cut out floor. My mounts were good and only need floors replaced. Passenger side just needed patching.
