67-72 F100/F250 door dome light brackets and switches with harness
Im trying to piece out the door dome light switch system on my 69 F250 since it didn’t come from the factory with one. I would need the harness first. If anyone is willing to part and sell. Thank you.
Re: 67-72 F100/F250 door dome light brackets and switches with harness
Highly suggest you save yourself some money and grief and replace them with dent era switches and harness(s) like i did BC #16.=sinaloagold post_id=773750 time=1645378311 user_id=122127
The bump era door switches have always been a part that needs constant attention due to the two small pins corroding/breaking/losing conductivity.
And you'll find the wires/circuit that feed power to the the switch(s) black w blue stripe tucked just inside the cab under the dash, (which can be fabbed very easily versus getting brittle 50+ year old wiring).
The actual switch is different, so they should interchange between dents and bumps? Thank you for the input.
Yes the dent era switch is different but they'll use the same mounting holes, (they have "blade" type terminals versus the tiny pin type our bumps came with-a much more reliable switch).=sinaloagold post_id=773828 time=1646410126 user_id=122127]
So you do have to change the two wire harness at both doors as well, (an easy task).
I need the right and left door panels for my 72 green explorer special they are the high trim sport custom
