Torque Wrench Question???
When you are going to tighten a bolt to a specific torque setting what is the correct start point i.e. should the bolt be finger tight before you start torqing?or what?Thanks
re: Torque Wrench Question???
thats what I do. they won't register anything till you get a certain amount of resistance.
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
- heep70
Start there and then I increase in increments of 10lb if there is a more then one bolt or nut. ie head bolts
ei, ei, oooooooooooooooo
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
And if you are using a 'click' type torque wrench, be sure to set it back to 0 when you are doen. You sould not store those wrenches with tension on the spring.
