headlight upgrade?
- adrianspeeder
- 71PA_Highboy
re: headlight upgrade?
Parts List
DelCity.net:
1110102 White Primary Wire, 10 Ga (100 ft. MIN)
1114101 Red Primary Wire, 14 Ga (100 ft. MIN)
1114104 Green Primary Wire, 14 Ga (100 ft. MIN)
2812 Aluminum Loom Clamps, 3/4" (100 MIN)
72385 50 Amp Auto Reset Metal Circuit Breaker Need 1
73570 Prewired Relay Socket, 14 Ga (1 MIN) Need 2
73980 Change Over Relay, 12V (1 MIN) Need 2
779 High Temp Loom, 3/4" (50 ft. MIN)
784 Black Slit Loom, 3/8" (100 ft. MIN)
8145 Black Thrifty Spool, 14 Ga, 25-ft (1 MIN)
Comagination.com
#H4-M-HD-3T Housing Need 1
#H4-F-W-3T Housing Need 2
The rest is just to pretty it up...
I prefer the 50A Circuit breaker to the fuse because if the fuse blows you have to have another one... the CB will rest itself.
There are a couple of diagrams already posted, and I have my own, but with the information provided you should be able to make you own.
The nice part about this parts list. if something goes TU, you can just plug in your factory harness and limp home with crappy lights... no cutting, no mods to the harness.
hth,
Eric
DelCity.net:
Comagination.com
hth,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- ICEMAN6166
i make my own.only thing i buy from the store is the relays and the plugs for the relays and if i need it ,some wire.
i also have mine set up so i can use high and low beam at the same time if i want.
IMO one of the best things you can do for these older ford trucks and cars.
http://fordtruk.com/forums/album.php?ca ... user_id=26
you can ford a river or stream and get to the other side, if you dodge it you will not, and if you drive a chevy to the levee it will run dry and the music will die.
