dual carbs?
hotrod ford
dual carbs?
Post by hotrod ford »
did any size bump ever have these from the factory?
1971 Sport Custom SWB: 360/C6 3.00
1965 Ford Falcon 4Dr: Inline 170 3sp
FORDification
Site & Forum Admin
Site & Forum Admin
Re: dual carbs?
Post by FORDification »
No. All V8 bumpside trucks came with a 2-bbl, all 6-cyl came with a 1-bbl.
GSequoia
Re: dual carbs?
Post by GSequoia »
FORDification wrote:No. All V8 bumpside trucks came with a 2-bbl, all 6-cyl came with a 1-bbl.
Sorry to have to pull this on you Keith but that's not entirely true.
Bumps with the Generator PowerPack did in fact have two carburetors, one on the engine and one on the generator. :hd:
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
FORDification
Site & Forum Admin
Site & Forum Admin
Re: dual carbs?
:lol: Yep, I guess you got me there! :thup:
OldRedFord
Re: dual carbs?
Post by OldRedFord »
None of them came with a 4 barrel?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Redcap
Re: dual carbs?
Post by Redcap »
OldRedFord wrote:None of them came with a 4 barrel?
Nope.
OldRedFord
Re: dual carbs?
Wow. What a let down there Ford.
Im sure they had their reasons tho.
Tim
GSequoia
Re: dual carbs?
Post by GSequoia »
OldRedFord wrote:Wow. What a let down there Ford.
Trucks weren't really seen as sporty until later on, they were mostly utilitarian.
FORDification
Site & Forum Admin
Site & Forum Admin
Re: dual carbs?
Well, generally speaking, you add a 4bbl carb when a 2-bbl won't add enough fuel at higher RPMs. Since these trucks were designed to be workhorses usually running at relatively low RPMs, a 2-bbl will give it all the fuel it needs.
DIXONBOY
Re: dual carbs?
Post by DIXONBOY »
I have a 4bbl cast iron intake for a FE motor on my truck. Any idea what it might have have came off of???
Redcap
Re: dual carbs?
Post by Redcap »
DIXONBOY wrote:I have a 4bbl cast iron intake for a FE motor on my truck. Any idea what it might have have came off of???
A car. Post some numbers if you want to find out specifics.
Redcap
Re: dual carbs?
Post by Redcap »
Why? These old beasts didn't need a 4bbl carb. They run just fine with the old 2bbls.
Darren
Re: dual carbs?
Post by Darren »
My intake is a 4v cast iron job. I don't remember the number, but there was a D, a 5, and a T. 1975 truck?
"Do it now, or wish forever that you had."
ArizonaDan
Re: dual carbs?
Post by ArizonaDan »
Understand the engineering behind carburetor selection:
The number of barrels is by itself an irrelevant measure. The useful factor is CFM; 'cubic feet per minute' of air flow into the engine.
Whether you achieve, for example, 600 cfm through 2 or 4 barrels, the engine depends on the 600 cfm and NOT the number of barrels the air flowed through in getting into the combustion chambers.
One barrel, two barrel, tri-power, six-pack, four barrel, dual quad, throttle body, TPI, whatever, the engine requires a quantity of air and couldn't care less how many barrels the air has to flow through to do its job.
That being said, it is a fact that more barrels typically enable greater quantities of air to flow and that is why you see multi-barrel carburetors or multi-carburetors being utilized on larger displacement engines.
I am a marine engineer by trade and appreciate the verifiably proven science behind the numbers of internal combustion engine operation.
Why do I like these old Fords? The simplicity baby, the simplicity. :thup:
1968 F100 -360, 2BBL, C6, 3.25, ugly? yeah, she's ugly.
1997 Expedition -4.6L, 4WD, 14MPG, gutless? yeah, she's gutless.
2001 Kawasaki ZRX1200R, fast? yeah, she's fast.
GSequoia
Re: dual carbs?
Post by GSequoia »
A marine engineer in Arizona?!
