Truck cab shrinking?
Has anyone else had this happen? In high school three or four of us could ride around in my '71 F100, no problem, double dates, whatever. Fifteen years ago me, the wife and two kids could drive around the same truck comfortably. Now, me and a friend or me, the wife and the new baby in the cab is about it. Is there any ratio as to years per shrinkage? Just wondering
Re: Truck cab shrinking?
its just your idea of space you need to be comfortable is changing.
- robroy
Good evening Dssco,
I've noticed this as well! The entire cab in my F250 has decreased in internal volume quite a bit since I was a teenager.
I don't have any old photos of me in it back then to prove this, but you can see how tiny my cab is today--why, it's barely large enough for me to sit in there and operate the controls!
And I can see how badly some guys have this problem; just look at this poor truck:
Robroy
Robroy
- wildcard
I've noticed mine shrinking from front to rear. Not as much room between the stomach and steering wheel as there used to be.
- ForingaMex
But I took care of that problem, I just shortened my steering column some. It also helps that I have tilt steering. We are all good again.
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
Theres a reason no one buys regular cab pickups anymore.
71 3/4 ton 4x4 highboy
68 Mercury Monteray
68 Mercury Monteray
- kyle ray
I've notice my clothes shrinking.
I'm with you brother. All 6ft and 265lbs of me! LOL
Kinda strange how that happens, isn't it?
I remember going on at least one double date in my 71 F100 before I met my wife. Seemed like I had plenty of room to drive and it was a manual steering with 3 on the column truck back then.
Clint
Clint
71 F100 SportCustom
460 C6. Disc Brake/Power-steering/automatic Swap. 3.00
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Just got back from playing basketball with the other nieghborhood geezers. I just had to measure the distance from the gut to the steering wheel. Answer is 5.25 inches.
