Found a 69 door to replace my crunched door but the interior door latch is different. Will the door release from my 67 fit the 69 door or do I need a 67 door?
Thx
the latches are different for the 67 vs the 68-72 door latches. they wont interchange. the only way a door latch will fit to the stricker is to swap sides with a 68-72 drivers side to a 67 passenger side. and viseaversa. the interior hanld mech wont interchange between 67 and 68-72 at all.
Where are you located wildmtn67f100 ??
I have a pair I picked up. They are pretty much gutted but the sheet metal is straight save the mirror mount holes. you could re-skin your old ones or swap over the guts if you're close enough.
well find out how much im up in washington if there in relly good shpe i will py for shiping and wht ever you wanted for them if its under $300 all together
randymartinjr wrote:well i jst found 67 in my area going to look at it on thursdy so i will hve to get back to you
Awesome, I'd hate to see anyone have to spend that kind of money for a set of doors. As bad as I want to pass them on and help out, I have a few dollars in the doors myself and couldn't just give them away. Good luck with your find!!
Hate to revive a stale thread, but I'm in need of some guidance. I searched, but couldn't find anything on point.
After a few years of swapping cabs, doors, and whatnot, I'm currently left with a great 70 camper special cab, a great set of '67 door shells, and usable guts out of a '69 door.
I know 67 door internals were one year only. What do I have to do to get this work with what I currently have?
I was thinking of power door and window kits. Does that simplify or complicate things?
