im ordering over $250 worth of POR products (engine painting kit, 4 quarts of POR-15, plenty Metal Ready, brushes etc.) this very second, your post makes me more anxious to get them and to get started!
I have a 80 gallon one I bought at Lowes for $650ish, made by Campbell Hausfeld, rated at 16 cfm at 90 psi I belive.mrsnicks wrote:What type/size compressor are you using to run that sandblaster?
Looks good. Thinking about getting one myself but not sure my compressor is up to the challenge.
Patrick
First off--BobbyFord wrote:That "crusty old 9" has a nodular pumpkin...
Taken from a Mustang & Fast Fords article....67mann wrote:First off--BobbyFord wrote:That "crusty old 9" has a nodular pumpkin...lookin good ORF--definatly agree with the sandblast route
as long as you got the compressor to support it(my first one didn't make it)while your doing it.
I gotta ask---nodular pumkin--what does that mean
The highly sought-after 9-inch "N" case was born of a need for a super-durable 9-inch casting that could take the punishment of both NASCAR circle track and NHRA drag racing. The "N" stands for "nodular iron" case, indicating the solid iron material used. At a glance, the "N" is the quickest way to identify the nodular-iron 9-inch case. But, not all "N" cases received the "N" marking in the casting. Look for the C2AW-A, C4AW-B, and D0OW-B casting numbers when the "N" is missing. Another strong clue for the "N" case is 31-spline axle hubs and shafts. But, finding 31-spline hubs and shafts does not always mean you've found an "N" case. This is why your homework must be thorough. All of the elements of an "N" case must add up.
The N stands for nodular iron, which is made by adding magnesium to molten iron. What this does is change the grain structure from flakes to nodules - much stronger and less likely to fail under shear load.
at the crank.......... or the tiresOldRedFord wrote: Read that with that work, and the .520 lift cam and headers, and intake, Ill be looking at 425-450 hp and 520-530ft lbs of torque.
Tire burner!
