I pulled it out and had it tested at orielly's, made a hell of a racket when they started spinning it up. It pulled low volts and amps, but still worked.
So I bought new front and rear bearings and new brushes and decided to give it a try, truck is in a million pieces now so not much to lose,
Anyways after a lot of muscle and curses, I have it all apart, the front pulley nut was a bitch and a 1/2 and the rear bearing did not want to leave its home, came out in several pieces before it was over.
However before I start reassembly with the new parts, I noticed one of the little paper/plastic separator pieces is missing from the inner ring of wires. Do I have to have this, I looked around and cant find it anywhere, so if I do, I am screwed.
Thanks!
