installing windshield
anyone do this? I have the Ranger moldings. I have been told to have a 12 pack of my favorite beverage iced and waiting, it is gonna be a lllooonnngggg day! My glass company refused to put it in!
anything worth doing is worth doing in EXCESS!! - Carroll Shelby
70 F-350 4X4 crew
70 F-350 4X4 crew
- 69rangerf100
Re: installing windshield
from what i have heard you have to put the seal around the glass the insert the the trim into the slot. then you very carefully install the glass in to the window area. im not sure but i think you may need to put down some of the auto window silcone
David
- Thunderfoot
Shayne
I'm not "Brand Loyal" Ford-Chevy-Dodge-Toyota I have them all, one even cross mixed...
If it Looks good and Works good then it's ok by me. Everything has its issues from time to time...
69 SWB (project) & 69 Highboy (driver/project)
http://s197.photobucket.com/albums/aa29 ... d%20truck/
http://www.fordification.com/galleries/ ... ?cat=10399
- 1971ford
Shayne,
I see your windshield installation thread and I raise you a slightly more informative, windshield installation thread
http://www.fordification.com/forum/view ... on#p215346
-Ryan
Its rather easy to put in, get the windshield in the rubber first. Put the chrome on, which might be rough. If its a new rubber you will need some wd40 probably. Get a rope and install it in the rubber, make sure that both ends of the rope come out on a side. Get someone to help you. Put the bottom in first, have someone push on the windshield, and start to rope it in. Sometimes when it's not all the way in, you have to do a slapping motion on it. It really shouldn't take that long. If it's a new rubber, then you will need a hook tool and some wd40. Spray the wd40 on the outside. And hook a piece in and start to rope it in.
Hm, if you lived up here Id help you out. I install windshields weekly at my job.
No, don't put down silicone, you can use urethane if it leaks slightly from the top. But you have to put it after you installed the windshield. Our windshields are what I call rope in, no sealant needed, you just roped em in.
- 1971ford
How can it not be a new rubber? If you can save an old windshield weatherstripping and re-use it... you've got some ninja removal skills...JMcTurnan wrote: Put the chrome on, which might be rough. If its a new rubber you will need some wd40 probably. .
-Ryan
- Thunderfoot
1971ford wrote:How can it not be a new rubber? If you can save an old windshield weatherstripping and re-use it... you've got some ninja removal skills...JMcTurnan wrote: Put the chrome on, which might be rough. If its a new rubber you will need some wd40 probably. .
Shayne
- flyboy71
Im not touching that comment being this is a family forum and all.1971ford wrote: How can it not be a new rubber?
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
urethane is soem sticky and hard stuff to get back off. these trucks usually had leaks at the top drivers side roff pillar seem to roof. a flowable silicone later will seal up any leaks. urethane is what they use now days to seal a windshield into cars and trucks without windshield gaskets. it is made so the windshield wont pop out in a wreak.
rattlecan,
This is also one of the things in my build that I have to do. I've got a one year old piece of glass from my 79' and a new "trimless" gasket.
I'm really not looking forward to this...
I stopped some guy up the road here last week (pro's) that were replacing a neighbor's windshield. They said "no problem / we'll come by tomorrow and get it done for you" they never showed...
I coulda' swore that Keith had a tutorial on this, (I do remember reading of his install a few years back and felt it was an excellent description on "how to" do the install). But i can't seem to find the tutorial or the thread now.
I'm still not looking forward to this either...
Thunderfoot wrote:1971ford wrote:How can it not be a new rubber? If you can save an old windshield weatherstripping and re-use it... you've got some ninja removal skills...JMcTurnan wrote: Put the chrome on, which might be rough. If its a new rubber you will need some wd40 probably. .All depends on your "perspective" of old
a couple of years old would still be flexible enough to remove and reuse...
Yes, too old and they are frail and break easily. New ones that have never been installed are tight, and sometimes hard to get in. Lol man, Ive saved many old windshield weatherstrippings. Now if it's never been replaced on these trucks, more than likely it will mess up coming out. But in reality if the rubber has been replaced in the last 25 years it should come out with no problem and be reused. Never cut the rubber to get the windshield out, sit on the seat and push the windshield out with your feet. "Not kick"!, Push. If you got a fresh paint job then put a furniture blanket over your hood.
Well the way we have always done it, the windshield 98% will leak from the top. So you stick the urethane tip under the rubber and drag a bead across under it. In my expirience, regular silicone usually doesn't last more than maybe 3-4 years.fordman wrote:urethane is soem sticky and hard stuff to get back off. these trucks usually had leaks at the top drivers side roff pillar seem to roof. a flowable silicone later will seal up any leaks. urethane is what they use now days to seal a windshield into cars and trucks without windshield gaskets. it is made so the windshield wont pop out in a wreak.
with the urethane you wont be able to push the windshield out any more and save that gasket. urethane will glue the gasket to the truck. it will come off but it has to be cut off of the metal. it is a liquid rubber kind of. use what you will. but consider the problems your mods may create.
