ot: anybody know anything about street bikes
- theskytoucher
I was wondering if anyone knew anything about a 98 yahama yzf 600, are they good bikes bad bikes wat to look for! I have a guy wanting to trade me a 98 yahama yzf 600 for my 95 honda civic and dont know if its a good deal or not so im looking for help!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- fomocoguy
Re: ot: anybody know anything about street bikes
My only advice to you is that if you're going to get a bike like that be sure that if it has been modified at all it was done correctly. Lots of guys will add performance exhaust but not jet them correctly, then proceed to run the snot out of them with a lean condition and cause premature wear and problems. Also they will put performance air filter assemblys in them and, once again, not jet the carbs correctly and run them lean. These engines are finely tuned and small changes in exhaust and intake flow can make major issues in how they perform if not done right. In my opinion the more original the bike is the better, that way if you want to modify it you can be sure and do it right.
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
The main thing is to look for signs of a crash. Replaced parts, scuffed engine covers. Scuffs on the frame are hard to fix so check that over pretty close. Look real close at the chain. You can tell by how clean and well maintained the chain is as to how well the bike has been taken care of most of the time.
If you are new to motorcycles I would strongly recommend the MSF course before riding.
Whether this is a good trade or not depends heavily on the condition of both items. Remember mileage on a sport bike is not really comparable to car mileage, 50,000 miles is a lot on a sport bike...
I personaly would not buy a used bike unless it was absolutely pristine and had indications of meticulous matenace...
Check it over real carefull before you buy it. If you don't have a good knowledge of used bikes find someone who does and have them check it out. My son took the PO word that it was in great shape,it was'nt quickly turned into a money pit. Buyer beware.
Another tell tale sign of it having been down are the steering stops (the tabs on the frame on either side of the lower tripple clamp). If one is broken off, it has been down HARD! I have tested that a few times in my 20's (86 ninja 600, 98 FZR600, 93 900SS). Also if the clip ons dont track straight, the forks are tweeked in the tripple.
- 390Nut
george worley wrote:If you don't have a good knowledge of used bikes find someone who does and have them check it out.
I couldn't have said it better myself, except to say that the someone you find REALLY knows what they are talking about, and not just all talk.
A tire out of balance on a car/truck is slightly annoying. On a bike, it can kill you quick, and thats just the tip of the iceberg.
`69 F100 390 4spd driver
http://www.fordification.com/galleries/ ... ?cat=10251
Dura-Spark II Conversion info at:
http://home.comcast.net/~390nut/Dura-SparkII.htm
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- theskytoucher
I decided not to get the bike! But i do appreciate all your input! I talked to the local cycle dealer/ service center and they gave me alot of incite. They told me that it would most likely need the top end rebuilt before to long and that it is a good bike but its nothing special and that a reasonable price for the bike is only around 1500 which is les then the car i would be tradeing for it!
Thanks
Thanks
-Troy-
1976 Ford F-150 4x4
1976 Ford F-150 4x4
