71 ford swb
71 ford swb
new to site, i just bought a 71 bump,but the grill is from 69,the cab is 70, the bed is 71!!
this is a bunch of throw together parts. the motor is 83 302, i put a 84 aod behind it.
the rear is ford 9 inch w/3.70 gears. my question is do you go strictly 71 or just make do with what
i have??? when i get better at this i'll try to add pics. gloss black paint w/red trim.chrome alloy
wheels, 50 series rear, 70 series front.
- Caseys71
Re: 71 ford swb
Casey
- jzjames
Re: 71 ford swb
Your new truck sounds like it could be nice. How long you had it? Hows the driveability? How much was it?
The 83/84 engine and tranny sounds like a good idea, and you got a good differential at 3.70. Wonder what that is like with the AOD, Sounds like a nice truck that could have been expensive!
Hope you get alot of enjoyment driving it.
- 1969FordMan
Re: 71 ford swb
Id rather see parts mix matched together into a vehicle tat to see one sitting around rotting. If you have money you make it complete, if you don you use what you have. I thinksome of the coolest builds I hav seen are budget builds using whatever could be found and a lot of hard work. I have seen some VERY nice trucks that were lovingly pieced together. You would be supriced how good a stock $400 Grenada 302 can be made to look in an old truck.
1969 F100. All factory 360, 4-speed, candy apple red one owner. Incredible truck!
Re: 71 ford swb
what you do with your truck is your opinion. if you want to completely retore it to original then do what it takes to do that. if you want to be something that you want to drive and be comfortable with do that to it.
- 1969FordMan
Re: 71 ford swb
I have an opinion, if you find a complete stock vehicle I say leave it be, but if you find a pile of part missing edrivetrain etc then build whatever you want. I plan on keeping my 69 one owner F100 bone stock, however I hav a 68 mustang thats baically a shell, that will be a custom street rod. I may get a 1970 F100 it will LOOK stock but have a modded engine. The older get the more I get into stock looking hot rods.
- marz68
Re: 71 ford swb
Just mix and match, i don't see anything wrong with that.
My truck is a 68 with a 70's short bed from a 4X4 plus my truck was a long bed when I got it.
Have fun with it a post some pics for us to see.
Re: 71 ford swb
You almost described my truck perfectly man!almost lost ford on Tue Aug 17, 2010 8:57 am
- 1982 flareside
Re: 71 ford swb
I got you beat in my truck FRANKENFORD well i have a 68 f250 with a '67 rearend housing with 72 gears, a 68 bed and frame, 69 doghouse, 70 engine ,71 cab, 72 trans with a 69 trans top. See it all right to have a mutt.almost lost ford wrote:new to site, i just bought a 71 bump,but the grill is from 69,the cab is 70, the bed is 71!!
Jeremy
Re: 71 ford swb
had about 1 year,little more work on tranny, it has b&m shifter, need linkage.turn signal and brake lights don't work.double check the brakes
and should be ready to drive. clear title under 71 ford.bought for $500. hopefully soon i will be headin down the road in her??!!
jzjames wrote:Your new truck sounds like it could be nice. How long you had it? Hows the driveability? How much was it?
The 83/84 engine and tranny sounds like a good idea, and you got a good differential at 3.70. Wonder what that is like with the AOD, Sounds like a nice truck that could have been expensive!Hope you get alot of enjoyment driving it.
Re: 71 ford swb
thanks for all your input it made up my mind to keep what i can and
build what i like.!!!!
