what size Tires
- daddysgirl
what size Tires
Can any one tell of what the appropriate size tires are for my truck? all 4 are dry rotted and one was flat by the time i got home:
'69 F100 Camper Special~Dad's Old Truck
- Mancar1
Re: what size Tires
What is your truck, and what size wheels does it have?
I put 235 85 16s on my 68 Camper Special. Good size to go with, it would be good in in a 15" also. Mine are BF Goodrich.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- daddysgirl
Re: what size Tires
it has 235 75r15 On it right now and from what tire dealers are telling me thats a hard size to find. what can i change the size to without changing the wheels? i found some tires that were new at wal mart for 75 ea but my goodness. i called 3 places today and was only able to find one used tire so i got it to replace the flat one
- 69rangerf100
Re: what size Tires
that is really weird that the dealers said that 235/75/15 are a hard size to find. that is the size that i had on mine till i ugraded to the 31x 10.50 15
David
- daddysgirl
Re: what size Tires
i Got to looking and the back tires are 30x10.50r15 and the front are the 235s so which size is the right one and which will be easier on my wallet?
- 69rangerf100
Re: what size Tires
here is the search that i did on nextag.com on the 235/75ra5 tires
http://www.nextag.com/serv/main/buyer/O ... 35%2F75r15
David
Re: what size Tires
I ran 235's on mine for years. It is a good size. I did some swapping and ended up with a nice set of 31-10.50-15's and it made the truck ride all that much better. Seemed to really smooth out the pot holes. I like the looks also
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Re: what size Tires
Check craigslist if you're looking at used tires, you can sometimes find good deals there
1970 F250 Camper Special
"Its no coincidence that man's best friend can't talk."
Re: what size Tires
In all honesty pretty much all 15" tires are getting hard to find decent ones, it is not quite as bad as 13" and 14", but...
What wheels you have (as well as the model) come into play as well, it probably came with bias ply tires that were the equivalent or an 80 series so what you have to do if using stock wheels is find one close to the same rolling diameter without being too wide to fit the wheel.
